Installation von PuTTy läuft auf einen Fehler
die Installation von PuTTy 0.83 läuft bei mir auf einen Fehler.
Die letzte Zeile im Log (SimonTatham_PuTTy_0.83_PSAppDeployToolkit_Install.log) lautet:
<![LOG[[Execution] :: The variable 'neoCustom' is not set in empirum or the custom cfg file is missing.]LOG]!><time="17:00:44.22460" date="02-18-2025" component="ApplyEmpirumVars" context="NT-AUTORITÄT\SYSTEM" type="1" thread="11304" file="ApplyEmpirumVars.ps1">
Danach ist Schluss.
Im SetupErrorLog:
Date/Time  : 18.02.2025 17:27:31
ProductName: PuTTy
Version    : 0.83
Revision   : 0
SetupInf   : C:\EmpirumAgent\Packages\Simon Tatham\PuTTY\0.83\neoInstall\Setup.inf
18.02.2025 17:27:31, Section [Set:neoInstallError], Line 5:
ErrorLogMsg: PSADT: - Errorlevel: - LogfilesDir: C:\ProgramData
eo42PkgsLogs\Simon Tatham\PuTTy\0.83
Im Log „SimonTatham_PuTTy_0.83_PSAppDeployToolkit_Install.log“ ist nach den Zeilen einfach Schluss:
<![LOG[[Execution] :: Checking for config file [Setup.cfg] under [C:\EmpirumAgent\Packages\Simon Tatham\PuTTY\0.83\PSADT\Setup.cfg]...]LOG]!><time="10:18:39.32860" date="02-19-2025" component="Set-NxtSetupCfg" context="NT-AUTORITÄT\SYSTEM" type="1" thread="4988" file="ApplyEmpirumVars.ps1">
<![LOG[[Execution] :: Read ini file [C:\EmpirumAgent\Packages\Simon Tatham\PuTTY\0.83\PSADT\Setup.cfg]. ]LOG]!><time="10:18:39.40360" date="02-19-2025" component="Import-NxtIniFileWithComments" context="NT-AUTORITÄT\SYSTEM" type="1" thread="4988" file="ApplyEmpirumVars.ps1">
<![LOG[[Execution] :: Setup.cfg file [C:\EmpirumAgent\Packages\Simon Tatham\PuTTY\0.83\PSADT\Setup.cfg] is valid.]LOG]!><time="10:18:39.50660" date="02-19-2025" component="Test-NxtSetupCfg" context="NT-AUTORITÄT\SYSTEM" type="1" thread="4988" file="ApplyEmpirumVars.ps1">
<![LOG[[Execution] :: Read ini file [C:\EmpirumAgent\Packages\Simon Tatham\PuTTY\0.83\PSADT\Setup.cfg]. ]LOG]!><time="10:18:39.52660" date="02-19-2025" component="Import-NxtIniFile" context="NT-AUTORITÄT\SYSTEM" type="1" thread="4988" file="ApplyEmpirumVars.ps1">
<![LOG[[Execution] :: [Setup.cfg] was found and successfully parsed into global:SetupCfg object.]LOG]!><time="10:18:39.54060" date="02-19-2025" component="Set-NxtSetupCfg" context="NT-AUTORITÄT\SYSTEM" type="1" thread="4988" file="ApplyEmpirumVars.ps1">
<![LOG[[Execution] :: Package configuration successfully parsed into global:PackageConfig object.]LOG]!><time="10:18:39.64960" date="02-19-2025" component="Get-NxtPackageConfig" context="NT-AUTORITÄT\SYSTEM" type="1" thread="4988" file="ApplyEmpirumVars.ps1">
<![LOG[[Execution] :: Read ini file [C:\EmpirumAgent\Packages\Simon Tatham\PuTTY\0.83\PSADT\setup.cfg]. ]LOG]!><time="10:18:39.67060" date="02-19-2025" component="Import-NxtIniFileWithComments" context="NT-AUTORITÄT\SYSTEM" type="1" thread="4988" file="ApplyEmpirumVars.ps1">
<![LOG[[Execution] :: Read ini file [C:\EmpirumAgent\Values\MachineValues\DOM-RSGV\CD1W10DT436.ini]. ]LOG]!><time="10:18:39.72260" date="02-19-2025" component="Import-NxtIniFile" context="NT-AUTORITÄT\SYSTEM" type="1" thread="4988" file="ApplyEmpirumVars.ps1">
<![LOG[[Execution] :: The variable 'neoCustom' is not set in empirum or the custom cfg file is missing.]LOG]!><time="10:18:39.75560" date="02-19-2025" component="ApplyEmpirumVars" context="NT-AUTORITÄT\SYSTEM" type="1" thread="4988" file="ApplyEmpirumVars.ps1">
Hat jemand einen Tipp für mich?
Gruß Silvio
Powershell wird auch beendet - ich sehe aber nicht wann und warum.
